Sony HD5 ff/rw question
Discussion in 'Headphones, Earphones & Portable Music' started by sohc, Jun 23, 2005.
  1. sohc
    sohc
    i finally got to the sonystore and couldnt resist. i bought an hd5 w/2 yr warranty.
    when i first got some music on it, i remember being able to tap > or < and it would fast forward or rewind instantly. to change the tracks i had to hit ^ or V then Play. now... 15 album transfers later- the < and > controls operate like a CD player (press and hold to ff or rw). And when i hit ^ or V, it goes directly to the next track without having to press play.
    how do i get it back to the old mode!? i looked in the manual no luck. all ive got are regular mp3s.
    any help would be appreciated, thanks
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    I can't reproduce your first situation.
