joeyjoejoe206
iv had a sony hd5 for some years now, and only ever had one problem with it which i was able to rectify with a reset using the secret menu. The other day after the battery light had been flashing it cut out, and since then has stopped working. The player lights up when its turned on, and the loading screen appears, but then it cuts out. It will not recognise charge via usb or mains, and does not show up on when attatched to the computer. As it never fully turns on i cannot use the secret menu, any ideas as to where from here?
thanks
joe
thanks
joe
