sony hd5 converting bit rate
Discussion in 'Headphones, Earphones & Portable Music' started by scratchyjase, Sep 22, 2005.
  1. scratchyjase
    scratchyjase
    Mar 27, 2005
    603
    +9
    i have been loading my cds on no the hd5 at 64 is there a way to convert it to a higher bit rate or is not possible?
  2. drmoze
    drmoze
    Aug 8, 2005
    196
    You can't convert the files already loaded to a higher bitrate (and would not get any improvement in sound quality if you did!). You can rip your CDs at 192 or 256 for the HD5. I was originally going with 192, but tried double-blind tests on a few different types of songs using different headphones (hitting the randomizer button a few times and checking the bitrate after listening and guessing) and I didn't catch a major difference. 192 might be preferable if you're going to play songs over a real stereo a lot. For headphone use, my aging ears think the 64 rate is perfectly fine, so I went with more songs at lower bitrate!
  3. shadowritten
    shadowritten
    My ears agree: 64 is perfectly acceptable - even through my entry-level separates Technics system using the HD5's line out.
  4. DanDT
    DanDT
    Aug 31, 2005
    847
    28
    London
    +23
    One thing that i don't get is that sometimes i transfer music to the HD5 from MP3's and they don't seem to convert to ATRAC.
    I know that it doesn't convert anything that's lower bit rate than the selected ATRAC bit-rate, but sometimes even the MP3s that are higher bit rate than what i selected don't convert... Oh well...
  5. shadowritten
    shadowritten
    MP3s go over 'as is' (plus a 'wrapper' added by SonicStage). You have to tell SS to convert them to ATRAC.
  6. robhimself
    robhimself
    i have this same problem, only my mp3 tracks work, the rest, ripped from cds, transfer at 64kbps when i ripped them at a higher level. i cant change it, and these lower quality tracks skip and sound generally worse than the mp3 files.
  7. shadowritten
    shadowritten
    Are your MP3s CBR or VBR?
