Sony HD5 Bitrate question...
Discussion in 'Headphones, Earphones & Portable Music' started by guernica2000, Sep 18, 2005.
  1. guernica2000
    guernica2000
    Why does the player only accept 64 or 192 at Atrac3Plus. Is that normal or am I doing something wrong?
    Thanks in advance.
  2. shadowritten
    shadowritten
    Almost all the new bitrates provided by SS 3.2 (other than those you've identified, plus a couple of others - 48 and 256) aren't yet supported by the HD5. So yes, it's normal!
  3. guernica2000
    guernica2000
    Damn, that's annoying...
    Thanks anyway
