sony hd3 only one channel
Discussion in 'Headphones, Earphones & Portable Music' started by steptoe, Dec 30, 2006.
  1. steptoe
    steptoe
    Aug 24, 2005
    597
    28
    +56
    hi
    my mates got a sony nw-hd3 when he plugs the headphones in he only gets one channel is it worth paying sony £80.00 to fix it or just buy another off ebay for £80.00 as i presume its the headphone socket thats damaged
    thanks
  2. HD3
    HD3
    If you've checked its not the headphones (use another pair) & checked its not the track then i would just buy a new one. If your going to replace the unit then it migt be worth trying to fix it. I belive they are fairly simple to take apart. (manual has guide,,,,, for battery removal). You could follow this guide into the player and look to see if its something you could fix.
  3. steptoe
    steptoe
    Aug 24, 2005
    597
    28
    +56
    cheers hd
    ill pass the info on if its broke anyway he might as well open the little sucker up and have a dig around
