sony hd3 help
Discussion in 'Headphones, Earphones & Portable Music' started by FLIGHT101, May 29, 2005.
  1. FLIGHT101
    FLIGHT101
    o.k this might seem like a noobie question but i've just had to re format my harddrive!! and i was using sonic stage 3 now that i've re done my harddrive and installed the old sonic stage 2.3 it says that my mp3 player with not work with this version of sonic stage! so i downloaded and installed sonic stage3.1! now it says i need to re initialize my hd3 but i have no idea how to do this so any help would be great!! thanx!
  2. FLIGHT101
    FLIGHT101
    sorted! no need for any help
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    How did you fix it?
  4. OneMoreSolo
    OneMoreSolo
    Mar 17, 2005
    852
    28
    +47
    All you have to do is go to the menu on the HD3, and reformat it.
  5. FLIGHT101
    FLIGHT101
    you don't re format it (but that is what it does!) you have to re initialize it!! they are 2 different options in the menu section of the hd3! they are right at the bottom of the menu!
