Sony HD3 & HD5 Service Menu
Discussion in 'Headphones, Earphones & Portable Music' started by emqav, May 29, 2005.
  1. emqav
    emqav
    May 29, 2005
    32
    Hi there,
    In the first place I wish to thank the author of the "European Volume Solution" for the NW-HD's Sony. I tried and it was a success (although I would like to have even more volume, just for some musics....) :)
    But the main question here is about the other options of "Service Menu".
    There is an option CLOCK which I selected and then it gaves me an OK answer. I hope I did not mess with anything serious but I would love to know what does that means ?
    Also it would be great to know is there is any other interesting options to deal with (perhaps the copy of the Service Menu Manual...... :clap: )
    Thanks for all your help and best regards to all of you.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,243
    +6,449
    you mess with service menu at your own risk (apart from removing volume limit). Some on this forum have reported players freezing after messing about. :)
  3. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    I wonder why CLOCK is mentioned in there, there seems to be no clock (visible) on the device.
  4. emqav
    emqav
    May 29, 2005
    32
    Yes and when you select it gaves you an OK answer. I wonder why ?
    Is it measuring something ?
  5. altecc
    altecc
    May 27, 2005
    37
    I read something about DL'd music with rights, after 30 days, it dies (unless you sync). Maybe it resets that clock?
    Tom.
  6. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    I wonder if you can turn the clock off? If so, do you get unlimited access to DL'd music?
    Just a question as I'm too chicken to try it on my HD3.
    Njiri
  7. Hasselhoffia
    Hasselhoffia
    My (some would say educated) guess is its not the time clock you are thinking of but the clock for the timing of the internal components of the device, and that this menu option is for the service technicians to verify that the input clock frequency is correct for the various chips and so on inside. Whilst you can overclock CPU's on PC's, I'd very much advise against trying to overclock your HD3. Particularly if you don't like Alvin and the Chipmunks.
