sony hd3 and sonicstage help
Discussion in 'Headphones, Earphones & Portable Music' started by 2pac-is-alive, Aug 5, 2005.
  1. 2pac-is-alive
    2pac-is-alive
    firstly is there any point in spending money on a hd5 or is there much diference between it and hd3 as i was going to get hd3
    also is sonicstage rubbish on everything except windows xp cuz i read somewhere it was i have windows 98 pentiumIII will it work ok???
    plus all these usb things are confusing i have a usb port but dose it have to be a certain version or what
    Please help cuz i dont have a clue :lease:
  2. shadowritten
    shadowritten
    Personally, I find the HD5 to be a very good little player (had it a month). Relatively lightweight, very small - smaller than an iPod, anyway - and if you use Sony's ATRAC3Plus format you can make all your tracks play exactly like they are on the original CDs (perfect, as it won't put artifical gaps between tracks on, say, live albums).
    HD5 has fewer technical glitches and some improvements over the HD3 - a removeable 40-hr battery for one! And I think it will work with a PIII Win 98. As for USB, don't worry. Even if you've only got 1.1, the transfer will still work - it'll just be a lot slower than using a 2.0 USB.
  3. 2pac-is-alive
    2pac-is-alive
    ur a legand thanks a million
  4. cabster21
    cabster21
    May 19, 2005
    11
    HD3 is still very good, I personally didn't like the looks of the HD5. Though the battery is an advantage. The SS version I got with my HD3 2.3 was rubbish, but the 3.1 is a bit better, like when you transfer a file it doesn't like, rather than crash it just converts it for you. Still not fantastic but it does the job. I don't think there is a lot between them though.
