Sony HD3 and converting MP3's to atrac3+
Discussion in 'Headphones, Earphones & Portable Music' started by jmscott, Mar 24, 2005.
  1. jmscott
    jmscott
    Mar 13, 2005
    Does anyone know of a way to convert my mp3's to atrac3+ 64kbit/sec.
    I thought it would be easy but I have tried several ways and eachtime the mp3 conversion tool keeps saying that "none of my files require conversion", so it doesn't even startup. I think this is because the HD3 plays mp3's native. The only way I have succeeded is to use the automatic transfer option and this does convert them as they are transferred. However, this is only at a bit rate of 48kbit/sec, which cannot seem to be changed, which seems good but I would like to try a higher bit/rate. Most of my MP3's are at 192 kbits/sec but I have read reviews that say that the HD3 works better with atrac3+ and a lot of the sound functions only work with atrac format. I am using sonicstage2.3 but I might try and download v3.0 and see if it is easily done from there.
    Thanks, John
  2. jmscott
    jmscott
    Mar 13, 2005
    I guess, by the lack of response, noone else has managed this either ?
  3. Kjetilb
    Kjetilb
    I wouldn't convert the files if I were you. :nono: Converting from one lossy format to another will inevitably lead to bad sound quality... And why would you want to compress your tunes so much? Both 48 and 64 kbit sounds terrible...
  4. toohuge
    toohuge
    Apr 3, 2004
    131
    +6
    Hello,
    Try going onto SOny's website and find the update for Sonic whatever it is and then download it, i think 3 is the latest not sure but i think yours may be out of date!
  5. dragthewaters
    dragthewaters
  6. dragthewaters
    dragthewaters
    what is the adavantage of using atrac? i heard that it makes the battery last longer, is this true?
  7. balbesina
    balbesina
    use ss 3.0 for resolve your problem
  8. malheuresement
    malheuresement
    Better sound quality to file size ratio, enables you to use additional sound features on the HD3.
    Its true about the battery life - something to do with the processor needing to do extra work to play mp3s. The 30 hr battery life is quoted for 48 kbps rate.
  9. jmscott
    jmscott
    Mar 13, 2005
    I shall give the file conversion tool a try and Soundstage 3
    I am not convinced that I need atrac3+ format but shall experiment.
  10. lammy
    lammy
    Apr 6, 2005
    71
    cheers 4 the conversion link, i will use this in the future
  11. lammy
    lammy
    Apr 6, 2005
    71
    i was wondering should i convert the files before i put them onto the hd3 or doesn't it matter??
    Also does it convert the files and replaces them or makes a copy of it? where is the converted file stored/saved?
