Sony HD1/HD3
Discussion in 'Headphones, Earphones & Portable Music' started by ultraviolent, Mar 25, 2005.
  1. ultraviolent
    ultraviolent
    Mar 25, 2005
    7
    I've heard people saying that you can't create play lists on the HD1/HD3. Just to clarify, this means you can’t make a permanent play list?
    I'm just making sure that it doesn't mean you can't queue up tracks while listening to something else on the player, as I wont be buying it if this is the case.
    Many thanks
  2. watchinthewheel
    watchinthewheel
    nope you cant make playlists on the hd3 though you can make them and import them from sonic stage and you can also bookmark up to 100 tracks to play them on their own at a later time.
