Sony HD-5 - Gapless playback
Discussion in 'Headphones, Earphones & Portable Music' started by GrooveyTunez, Jun 15, 2005.
  1. GrooveyTunez
    GrooveyTunez
    Jun 14, 2005
    157
    16
    One of the main reasons ive ordered my HD5 is because of gapless playback. Having looked at screenshots of the sonicstage software it looks as though you still rip the tracks off the cds seperately, but i assume when you send them over to the player they are merged? or to put it a different way, they only appear seperate when in the software, when infact its still one large file?
  2. davisneil
    davisneil
    May 15, 2005
    406
    +18
    hello again...
    Im being very handy tonite...
    The tracks appear separate corresponding to the trcks on the cd. However you will end up with gapless only if you do the following:
    1) Encode in Atrac3/plus (which i believe u are..
    2) If you have a 2 cd set, you need to tell the player that the discs are separte eg on mine i have ministry of sound clubbers guide. Firstly i tried using one album name for both cds to make it nice and neat. However the player cant work out which tracks belong to which cd and they are played interlaced..therefore u lose the continuity. However naming them MOS CD1 and CD2 separtes the album contents and they will play, gapless, in the correct order. Make sure you dont have shuffle mode on though.
  3. GrooveyTunez
    GrooveyTunez
    Jun 14, 2005
    157
    16
    Thanks again for your valuable help davisneil. Just finished listening to 2 new house albums and cant wait to get them on my new player!!!
  4. davisneil
    davisneil
    May 15, 2005
    406
    +18
    good music...whos the dj?
