sony hcd-sb100 speaker plugs wanted
Discussion in 'Home Cinema Buying & Building' started by pedro71253, Aug 11, 2005.
  1. pedro71253
    pedro71253
    i bought the unit with no speaker plugs and have no idea where to purchase them from so the unit is sitting there unused, any help would be so greatfull, they look like modem plugs sort of as i have only one and need five more for the surround sound. thankyou.
  2. SIGNALEX
    SIGNALEX
    i also have this same set but the problem is i get audio only when i play dvds nothing else
  3. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    I think those colour coded wotsits are unique to sony
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    you wont be able to buy them from sony,and i think you might,i cant seem to see them on partmasters site(they might be on there),so unless you could find them second hand,i think you are out of luck.
  5. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    You might find what you need here - I do not have a Sony system, but I hope this link helps you.
  6. prjwarren
    prjwarren
    May 2, 2009
    hi
    had the same problem, you can get sony speaker plugs via googling sony speaker plugs which leads you to various web sites selling parts. HOWEVER! if you're a bit handy and carefull you could use red crimp connectors trimed down and squashed. Bit of messing about but worth it. Up to you but the connections are about £20 and my old surround system is prob not worth much more, just be a carefull as you dont want to bend the prongs at the back but the connection is just as good, just done it to get mine working. Paul
  7. Presuming Ed
    Presuming Ed
    May 2, 2008
    1,510
    113
    Yorkshire
    +594
    Wondering if anyone can give me some advice on these colour coded Sony plugs...
    I snapped a wire by accident recently and now the cable isn't long enough. I'm no electrician, but if I buy a length of wire am I likely to be able to pull the existing wire out of the plug and replace it with a new one?
    Thanks for any advice.
