Sony HC96 gone - how to now import tapes?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by kata_tutu, Aug 1, 2012.
  1. kata_tutu
    kata_tutu
    Oct 9, 2007
    61
    My Sony HC96 was stolen from my car. I now have the problem of how do I edit my old mini-DV tapes or import them into my MacBook? I recall that the HC96 was filming in 'widescreen' - not sure if this was strictly 'true widescreen' or not. Do I need to get the same camcorder exactly to import my old tapes (not many around on Ebay). Will any mini-DV camcorder (even non-Sony's) playback and retain the 'widescreen' effect. I was using iMovie 6 HD on Mac in 16:9 format when importing. Sorry for essay.
  2. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    Any mini dv or hdv cam will play and capture your footage.
  3. kata_tutu
    kata_tutu
    Oct 9, 2007
    61
    Is that even if the camcorder does not have widescreen capabaility?
  4. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    as far as i know mini dv didnt have true widescreen but this i dont know for sure,but i can see no way that any mini dv cam would not play the footage,hdv cams were all widescreen.
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    The widescreen capability is produced by replacing pixels with black ones so the image is 16:9 with black borders in a 4:3 frame (The effective resolution is reduced). Transfer is the same, how it's interpreted by the capture software is the only difference.
  6. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
  7. rogs
    rogs
    Mar 16, 2008
    2,387
    Dorset
    +383
    The widescreen mode on my old Canon MV500 didn't add black bars, but merely changed the pixel display ratio - presumably by adding an appropriate 'flag' to the meta data.
    I suspect the Sony is the same, especially as the owners manual mentions the need to set a TV to display the 16:9 format correctly. (Obviously from the early days, when TVs were still all CRT, and had 4:3 and 16:9 display modes which weren't automatically set by broadcast 'flags').
    PAL DV video is always 720x576, so you can either crop with black bars to get 16:9 or change the pixel display ratio.
    So, the footage should replay OK from any DV camcorder (unless of course it was recorded in LP mode, which can give problems on different camcorders).
    Whether you'll need to set the TV display mode manually, to display the correct ratio?.....
    If you are intending to edit the footage in the future-- especially for display on a PC, or on the web -- then you would probably be better off resizing the 720x576 footage, so that you can display using square pixels. Makes life so much easier than faffing around with relying on aspect ratio display 'flags' to make your image look right!
  8. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Sony had a semipro model with a 16:9 720 x 576 output. A modified trv950 (Sony DSR-PDX10P). You dont see the black bars even a standard 950 but the true resolution isn't 720 x 576, it's extrapolated and noticeabally worse. The well heeled could buy an anamorphic lens which used the full sensor area (it cost more than the average camcorder). In any case the DV capture software I used to capture on the fly from mixed footage adjusting the par as required.
    http://www.avsforum.com/t/381131/16x9-camcorders
  9. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    Yes i had mini dv from 1995 including the best prosumer of the lot the vx2000
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,544
    Redditch
    +4,187
    Too poor in 1995 :D
  11. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    A knowledgable bloke like you knows it was the big step up from analogue that most craved.:laugh:
