Sony HC90 + memory stick question
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by scotte, Jun 22, 2005.
  1. scotte
    scotte
    Applogies for the newbie question but can anyone tell me if this camera works with a memory stick duo PRO?
    I initially ordered the camera and an original memory stick (which I now have to return) so I want to make sure that I don't order another incorrect one!
  2. DDRUK_Lawrence
    DDRUK_Lawrence
    Apr 29, 2004
    37
    The DCR-HC90E video camera comes with a 16Mb Memory Stick Duo and a memory stick duo adapter.
    The types of memory stick the camera will support are:
    Memory Stick Duo
    Memory Stick Duo (MagicGate/Parallel Transfer)
    Memory Stick PRO Duo
    On a Memory Stick PRO Duo the maximum memory capacity that can be used is 1Gb and the unit does not support high speed data transfer.
  3. scotte
    scotte
    Thanks Lawrence. Got a stick that works perfectly now.
