Sony Handycam DCR-HC40E upside down image in viewfinder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jaja4421, Jan 2, 2005.
  1. jaja4421
    jaja4421
    I just bought a Sony Handycam DCR-HC40E which I am very pleased with, but have noticed a little problem - the image in the viewfinder is upside down. The LCD screen is fine and works correctly. I don't want to embarass myself taking it back to the shop if I have just pressed the wrong button, so if anyone knows whether I have done something wrong or whether I have a duff model I would be really grateful.
    Thanks,
    Jon.
  2. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    To my knowledge no camcorder allows you to orientate the viewfinder image. It sounds to me like a fault. I would return it under warrenty and get a replacement.
  3. jaja4421
    jaja4421
    That's what I thought, but many thanks for the confirmation. I'll send it back.
