Sony GXD500 DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by alarustic, Dec 28, 2004.
  1. alarustic
    alarustic
    Dec 28, 2004
    20
    3
    Edinburgh
    +3
    Hello,
    I've recently acquired one of the above units. It's a fantastic jump from VHS, that's for sure!
    However, as has been mentioned in other threads, there are a couple of niggles with it. Most notably, you can't add a buffer when recording via the EPG. So I've missing the last 60 seconds or so of about 3 out of the 5 programmes I've recorded so far.
    My question is this, if anyone can help. Will it be possible for Sony to provide an update to the OS by CD or whatever method? Or am I stuck with this?
    For anyone who's interested, I made this unit multiregion by using the 1,2,3,4,5 Palm trick.
    Many thanks,
    Russell.
  2. JamesL
    JamesL
    Dec 20, 2004
    462
    Southampton
    +22
    I think we are stuck with it - thankfully setting a 'manual' timer is very easy. I am hoping (and expecting) an over the air update to the DVB side of things, i.e. the ability to remove channels, as has happened with the Sony V800U digibox.
  3. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Hi Russell
    What exactly is the 12345 Palm trick and how do you use it as I have one of these units but only region 2
    Dave
