Quantcast
Sony GX3,different recording times & quality
S
smallmanongn
Does anyone know how it makes recordings in the 2 hour mode as opposed to say the 1 hour mode.
I have done recordings in both and have analyised the discs on the laptop and it shows both the recordings being in the same bit rate and I cant really see any difference watching them back on the TV.
Basically what does it sacrifice to make the recordings fit.
johnhugh
My GX3 arrived last week and to be honest I cannot see much of a difference between 1hr and 2hr recording mode quality when played back on a TV.
John
S
smallmanongn
John
Exactly my point,so what does it sacrifice to be able to fit 2 hours on or is it supoosed to fit 2 hours per disc and it it just the 1 hour mode that is a "waste" of disc space?
PhilipL
There is a difference between 1 hour and 2 hour modes. 1 hour is a datarate of around 10Mbits/sec whereas 2 hours is half that.
Depending on your eyes, brain, the source and TV kit, you may or may not notice a difference as it is subjective when viewed by our eyes, that doesn't mean in 3 years time when you have a nice new super large screen TV your eyes will see the same thing.
Regards
Philip
