Sony GX-300 RGB in / pass-through
Discussion in 'Blu-ray & DVD Players & Recorders' started by turbohat, Nov 13, 2004.
  1. turbohat
    turbohat
    Nov 7, 2004
    330
    +3
    One last thing to confirm, before I buy one
    Is is definately RGB in and does it pas through in full RGB and widescreen switching even when the unit is off?
    Also what is the fan noise like?
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    I have a GX3 which does loopthrough RGB when in standby mode, and would be extremely surprised if the GX300 does not do the same. Widescreen switching also works in standby.
    As to fan noise on the GX3, I don't find it obtrusive, but have no experience with the GX300.
    Hope that helps.
    Cheers,
    Martin.
  3. turbohat
    turbohat
    Nov 7, 2004
    330
    +3
    Cheers for the info.
    Does the GX3 cope with DVDRs created on PCs?
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    I haven't tried that as yet, as I've only had the GX3 for a week so far.
    Cheers,
    Martin.
  5. turbohat
    turbohat
    Nov 7, 2004
    330
    +3
    np, can I ask if you've tried discs created with the GX3 with other players or a PC? Also, what kind of media have you been successful with?
  6. Hodman
    Hodman
    Dec 17, 2003
    117
    Warwickshire
    I have a GX3 and can confirm that DVD -R (Finalized) can be played across most other machines without problems.
  7. rhodos
    rhodos
    Oct 3, 2004
    1,640
    63
    Wirral
    +151
    Can the GX300 output the RGB in picture to the component out e.g. Sky+ in thru scart and out of GX300 to screen via component?
  8. xmb
    xmb
    Sep 29, 2004
    991
    46
    North Yorkshire
    +160
    I bet it will only output the RGB input (Sky box etc.) if switched on and the AV input selected to the RGB input. That will be the case for all DVD recorders, I am sure.
