Sony FX68 NTSC bug
Discussion in 'General TV Discussions Forum' started by stejcoolj, Jun 15, 2004.
  1. stejcoolj
    stejcoolj
    I've noticed that when I play DVDs which are NTSC encoded, the picture constantly flickers (light to dark).
    The flicker doesn't happen every time I play a NTSC DVD. Neither is it limited to region 1 DVDs - I have a number of Region 2 DVDs (NTSC) on which the flicker occurs. I never have a problem with PAL.
    I know it's the TV cos to get rid of the flicker I just have to power off the TV and then switch it back on.
    Does anyone have any idea what's causing it and whether it's a fault with my TV or the model in general?
    My DVD player is a Sony and I use RGB output via a Thor SCART.
    Cheers!
  2. Yoshimoto
    Yoshimoto
    Can't see it being the model in general as i've just bought a 28FX68 purely to play my games consoles on and they are all NTSC and work perfectly.
    Hope that helps.
