N
Nana
With the wisdom of the avforums help I bought the Sony fx68 at Christmas. At first everything was OK, but lately there have been odd colour flashes, especially when playing my Tosh DVD player in Svhs (the only way it will play as it's a US model).
The colour flashes occur whenever there is a lot of base (I think this model has a built in sub), and a transparent red or green flickers, across the screen.
I tried watching TTT yesterday and had to switch off as it was impossible.
I usually don't get this with normal telly, although there has occaisionally been the odd green tinge to the picture which lasted about 30 seconds, but that rarely happens.
Now before I have to go through the arduous task of calling a bloke out, has anybody else had this?
Or does anyone with knowledge think it's the TV that's at fault or my old DVD player, bearing in mind everything played perfectly when I first had the telly.
Another problem I had, it used to take up to a minute for the picture to come on in the morning although you could hear sound, but that seems OK now.
Any advice or conjecture would be gratefully received.
