Quantcast
Sony Fx68 Fault - help!
R
RichieS
My Fx68 is barely 6 months old and yet I have noticed a serious fault
Whenever I play a loud sequence through my centre speaker it causes a horizontal distubance lines on the picture of the tv....when the speaker is on top the lines appear near the top of the screen....when the speaker is below, the lines appear near the bottom of the screen
The speaker is magnetically shielded so I am assuming it may be a fault with the tv.....I would appreciate any ideas??
Rich
R
RichieS
Do you know of any reason how a speaker could affect a tv like this...when the speaker is below the tv it's not even touching it...at least 2 inch gap
cheers
P
Paul Atreides
Could be vibrations transmitted through the stand.
R
RichieS
HAs anyone else had problems with the centre speaker and their FX68?
A
AlinS
Hello,
Nothing is wrong w/ your tv. It is speaker`s fault and because you said that it happens even if it is under the set, probably the magnetic shield of your speaker is damaged.
Similar threads
