Sony FS76 owners....
Discussion in 'TVs' started by Manuman, Feb 17, 2003.
  1. Manuman
    Manuman
    Can one of you guys please post the values you have in the deflection menu (in the service menu)please?
    all 22 of them.
    It would help me out enormously.
  2. Bam
    Bam
    Check this link
    Deflection Service Menu
    It doesn't give any specific values but describes what each setting does from 0 to 17
    I know from a previous thread that the AFC Angle should be about 25 to 27 (It is factory set to 31), RGB Shift -10 and rotation -1 or -2.
    Hope this helps
  3. Manuman
    Manuman
    Thanks Bam, but i really need the specific values from another fs76 as a reference guide.
  4. Bam
    Bam
    Thought I would bump this to the front again
    Come on people!! Can nobody be arsed spending 10 minutes writing down a few numbers??
    mh66639 & cdave, you both have virtual perfection on you FS76's so would you both mind responding to this post...please?
  5. cdave
    cdave
    Dec 10, 2002
    306
    Just seen the thread. Sorry, it is not that I cannot be "arsed", I have already replied on the matter with an explanation. It is virtual perfect and I want it to stay that way! Check one out in Currys.;)
  6. Manuman
    Manuman
    Fair enough CDave, although i can assure you, it would be extremely hard to reset things by accident in your service menu as you are actually asked section by section if you are sure you want to change anything. Contributing to threads like this would be a good gesture, im sure you will need someones help on here sooner or later mate.
    Ive actually been into Currys and wrote down pretty much everything in the Service Menu, (took me about 20mins)which helped, but it would be nice to have a few references to correct values rather than just one.
  7. Bam
    Bam
    Are you going to post the settings that you noted in Currys?
    At least its a start and something we can compare to anyone who posts their perfect settings.
  8. Manuman
    Manuman
    Yes Bam, ill do it later.
  9. cdave
    cdave
    Dec 10, 2002
    306
    Thanks for that Manuman. I thought I had contributed a fair amount to your original post but it now appears I am being unhelpful because I will not risk messing my set up even though it is hard to do apparenlty. As a further contribution, always write down original values before making adjustments. Anyway, at least you now have some values through my suggestion. I hope they work for you.
  10. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    Well after reading that I could get rid of my DRC100 based horizontal lines, I braved the service window and made my adjustments and it is now great!
    Therefore as way of putting back into this helpful forum, here are my 22 deflection values ;) :
    39
    23
    23 (was 31)
    28 (was 29)
    17
    35
    35
    28
    30
    27
    15
    19
    155
    38
    5
  11. Tommo24
    Tommo24
    I am learning the ropes with my FS76 setup. I finally got my third FS76 today (after two previous faulty ones).
    The picture seems very good but can someone explain about the deflection set-up please?
    What does it represent and how do I achieve an alteration if required?
    Regards and thanks
    Tom
  12. Manuman
    Manuman
    Nice one ScottyToo for taking the time out to contribute as the values you posted have helped me a lot.
    heres the values from a set in my local Currys, although they are way out for my own TV though, (the Vertical and Horizontal size are set too high for my screen)which is why i needed another reference.
    44
    25
    29
    17
    37
    35
    27
    26
    15
    15
    55
    39
    5
    @ScottyToo, any chance you could post some of the other values on your set, like Backend, Ext.Deflection, Dynamic Convergence and Colour Decoder 1&2 as well?
    Threads like these will undoubtedly help those whose settings are not quite right as they give an idea of the range of values for each setting.
  13. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    Here's the others that I did at the same time (One of the menus had 122 settings :eek: )
    If you are really stuck I would try the values in the first column i.e. the defaults but I know nothing at all about these TVs so at your own risk ;)
    Backend
    40
    28
    25
    25
    45
    35
    42
    25
    20
    9
    Ext. Deflection
    170
    119
    135
    155
    175
    48
    160
    Scotty.
  14. Manuman
    Manuman
    Scottytoo, you are now my hero.
    The values youve posted have pretty much returned my TV to its former glory before i did a factory reset to try and solve my original problem.
    *telepathically makes scottytoo post the other values in the service menu too*
    :smoke:
  15. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    I typed all the values into my Psion.
    TBH I can't be ar4ed to re-type them all. When I go back to work I'll connect it up and up link it.
    I also noted all the ones that were non-default to speed up your process.
    Scotty
  16. Bam
    Bam
    Cheers Scotty your a good un'
    CDave.. I wouldn't suggest you have been unhelpful...far from it actually, Just that you and mh66639 were the only two names I could remember. You have contributed massively but there are others who I am sure read this forum without putting anything back (based on the fact that hundreds of people are ordering from John Lewis).
    If you don't want to risk messing up the settings on your TV then fair enough.. I can understand that totally.:smashin:
    Bam
  17. Enigma2
    Enigma2
    I've lurked here for ages before I even registered but have never had anything useful to say. I've had my FS76 from the beginning of December and I'm impressed with it especially with good source material. I did occasionally notice horizontal lines as described in the other thread but I simply associated it with lower quality source material as I didn’t notice it on good DVD’s. After reading about lowering my V size I braved the service menu and it seems even better now. Does lowering the V size need the H size to be adjusted too? Am I risking things being slightly squished on screen? It seems OK.
    I used the Avia set up DVD to get contrast etc set up to my personal levels. The movie mode is the closest but with sharpness lowered a fair amount and all the others lowered a tiny bit (I don't like too much colour). I watch in DRC 100 as I hate the flicker in the superior, resolution wise, DRC 50 mode. AI is on and I’m experimenting a bit more with noise reduction. I used to only use it on the VHS video source which worked well but after seeing someone else say that it helped with low bitrate channels on Sky D I am putting it on low occasionally and the effect is positive. It is on a case by case basis though rather than on all the time. My sources are a Sky + box, Pioneer 656 DVD player and now my computer with a Hauppauge 350 PVR card connected to the TV via its own S-Video output (it has mpeg decoder on the board). Plus a JVC VHS video but that hardly counts.
    I’ve attached some of my service menu settings as a zipped excel file. Note that my geometry is not what I would call perfect as in 4:3 or 14:9 mode the black bars are not straight. There is slight slant at the top but I'm not sure what to adjust to deal with it. With the exception of two settings everything is as factory set. If you try adjusting the V size make sure you test a NTSC DVD as you may get a blue line at the top of the screen so you'll need to adjust V position to get rid of it. When I first came here I used to say I'll never get as obsessive about service menus and geometry as "those people". How wrong I was. :laugh:
    The deflection options are
    36
    29 now 25
    31 now 32
    17
    35
    33
    27
    32
    26
    15
    109
    38
    5
    More are in the file
  18. Manuman
    Manuman
    Excellent post mate, thanks for your time and effort. im just off to check my settings against yours.
    Anyone feel like posting the Colour decoder 1 & 2 values?
  19. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    If no one does in the next 12 hours then I'll do them tomorrow.;)
  20. mh66639
    mh66639
    Aug 20, 2002
    148
    If you want any more I'd be happy to post.
    Sorry I missed your thread; I've been away for a while.
    Matt
  21. Manuman
    Manuman
    The more the merrier mate, it all helps.
    Btw, where can i obtain this Avia test disc thingy, and how much is it?
  22. Rookies
    Rookies
    Jan 4, 2003
    4,929
    103
    +349
    Could do with some FQ80 settings ;) to compare. But what I have not that bad at all really just always fancy to get it even better lol. I tried all these settings on here and they are no good at all for my FQ80
  23. Enigma2
    Enigma2
    I got mine from Ebay and paid £23 which is close to what you'd pay new for it but I wanted it quickly. You should be able to get it from most r1 retailers but watch out for customs since it is over the £18 limit. Amazon.com has it in stock at £24 but could get caught by customs. DVDboxoffice avoid customs but if it's not in stock (you can't tell from the site) you might be waiting months.
    All of the colour decoder settings on my TV matched the default values.
  24. Bam
    Bam
    You can get the Avia Guide to Home Theatre from various places, the cheapest I've seen it is about £25 import from US
    Alternatively you can get The Ultimate DVD Platinum from Australia for £13.51 (delivered to UK) - a bargain!
    Use This to find the best price
    Bam
  25. Manuman
    Manuman
    Your settings would help if you could post them too mate.
  26. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    im really beginning to think my FS76 is very dodgy.
    The image quality is ok, but really not that hot. Its very grainy too, but the most annoying thing happens all the time. If a dark object moves on screen it has a bright shadow going the whole way accross the screen?? One example is the obi wan and anakin duel with dooku. When anakin runs he has a bright shadow coming off him (crap terms i know), then when dooku lifts his hand this too has a shadow.
    Basically anything really dark on a darkish background causes it. Also as ive mentioned before, i have 2 horizontal shadows that appear on screen if the camera pans quickly up or down.
    I had a 9607 before this set and the image seemed better. At the moment i have a JVC avr25 in the second room and even it seems better.
    I have been waiting since before Christmas for a replacement from unbeatable and as yet nothing, i might get a refund and go for something else.
    Any ideas?
  27. Manuman
    Manuman
    Well, id be tempted to have a tinker in your service menu, Of course you should first write down all your settings, and then post them in this thread :), before changing anything.
    I dont really know what to recommend you change in your service menu as im not too well versed on Tvs, perhaps someone who does may be able to offer some advice.
  28. Bam
    Bam
    To date, from feedback on the forum I have identified 3 main problems with this set:
    1. Some have buzzing problem but this can be solved by replacing a part as described by mh66639.
    2. Some have blocks/lines/waves on dark scenes as described by Rox.
    3. All TV's (not just Sony) have minor wavey edge problem when showing rectangles containing text as described by AndyChap. The FS76 handles this problem better than others.
    It sounds like yours comes into category 2 in which case replacing the set should resolve it because it only affects 'some' sets...pot luck really.
    When Unbeatable send you another ask them to send 2 men and try to avoid rolling the TV end on end[​IMG]
    Hope you sort it anyway
    Bam
  29. Manuman
    Manuman
    Yes, rolling the TV end on end may upset the geometry somewhat, although the TV is dammned heavy (wait til u see just how heavy it is BAM)so it would be easier...:D
  30. ScottyToo
    ScottyToo
    Oct 13, 2002
    94
    Essex, UK
    +3
    Apologies for setting expectations and breaking them. It's been too busy at work and I'm not in tomorrow.
    I'll try again on Thurday to post the menu values.
