Sony FS76 - B&W DVDs
Discussion in 'TVs' started by marineboy, Feb 18, 2003.
  1. marineboy
    marineboy
    Nov 5, 2002
    20
    At long long last my FS76 arrived (new stock too - no apparent issues as with last year's batches).
    Anyway, I plugged in my DAV-S550 DVD player using an s-video to scart cable (no scart output on DVD player! Great thinking Sony) - plugged in to AV2 on the telly (the one marked DVD!). For some reason I can only get playback in B&W. If I move the scart to AV4 it works fine.
    Any suggestions please: (1) possible resolutions? (2) better ways to connect these 2 bits of kit? The picture's ok but not jaw-dropping.
  2. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    are you sure AV2 supports s-video or have you told it that it's connected to a s-video source (not sure about Sony but on my panny you have to tell it)
  3. Ashy
    Ashy
    Jan 3, 2003
    350
    Ive got a DAV550 plugged into AV3 mate on my FQ75 using a QED svideo lead and it works fine (no B&W)
    However, to play SVCD and VCDs I had to go into the service menu to turn on NTSC support for AV3.
    Are you using R2 dvds? As they should be fine as standard.
    With regards to best way of connecting I got told from various sources (on here, hifi shops/web sites) that using a high quality svhs to scart lead is the best way of connecting (on a DAV system anyway)
    Hope that helps :)
  4. marineboy
    marineboy
    Nov 5, 2002
    20
    thanks for the info. I have the 550 connected to the tv via s-video to scart but am told that rgb to scart is better (into av2).
    any views?
  5. clearys
    clearys
    Dec 16, 2002
    125
    Sheffield
    +12
    On the FS76 - AV1 & 2 are RGB and 3 & 4 are S-Video
    It assumes you'll be using RGB form DVD so thats why it's labled that way.
    I used to use S-Video for DVD but recently upgraded to RGB with a QED RGB only scart cable. Can't say I've noticed a lot of difference but I've not compared them side by side.
  6. Tommo24
    Tommo24
    I have the Dav 770. Had same B&W problem. Only resolution I have found is to move to different AV. No noticable difference in picture quality though (to my untrained eye).
    Regards
    Tom
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Scart 1 & 2 are RGB - so new DVD player time:)
