Sony FQ80 Black & White?!
Discussion in 'General TV Discussions Forum' started by Jamiethorpe, Apr 19, 2003.
  1. Jamiethorpe
    Jamiethorpe
    Hi all,
    I've just taken receipt of a brand new Sony FQ80 as an exchange for my black bar riddled Philips 9617 and am having problems setting the thing up.!
    I've connected like this:-
    EXT 1 - NTL Digi-box
    Ext 2 - DVD
    Ext 3 - VCR
    Ext 4 - Empty.
    The problem I have is that the NTL box will only pump out in black and white unless I change the digi-box setting output down from S-Video to Composite. (Obviously the composite feed is less desirable as the quality is tosh!)
    Ext 1 is RGB enabled (unlike the digi-box), so I've tried the digi-box in all of the other sockets (3 & 4 are S-Video enabled), but it still comes out as black and white no matter what I try.
    Am I missing a trick here or do I need to pretend my digi-box is faulty so that NTL give me a new RGB enable one?!
    Many thanks Ladies & Gents.
    Jamie.
  2. t-force
    t-force
    May 2, 2001
    1,852
    Southampton, UK
    +143
    You're certainly not going to get colour if you're trying to hook up an S-video feed to an RGB enabled SCART. I'd give SCART 4 another go - I'm pretty sure that the higher end Sonys should detect and switch between composite and s-vid, but I could be wrong (certainly my 32FX60 does). If that don't work, you may have a problem with either box or TV, so you could try the "faulty box" plan, and see if it works.
  3. Jamiethorpe
    Jamiethorpe
    Thanks for the reply.
    I've currently got the STB connected through Scart 4 now, but still black and white on S-video.
    I think your right, time to drop something heavy on top of the STB ;)
