Sony FQ80 and Shelf Heights
Discussion in 'Televisions' started by mansell, Feb 28, 2003.
  1. mansell
    mansell
    Feb 11, 2002
    754
    28
    Bristol
    +39
    I'm almost certain to buy one of these set's once I get the cash back for my PB50 which has just been collected
    What I need to know is Are the Shelves adjustable ?
    In JL in Bristol the top shelve appears to be on stud's but in every picture I've seen they are slotted into the legs of the stands
    I also need to know the gaps between the shelves as I need to know if my SR5200 will fit
    Can somebody also advise of the gap between the bottom shelve which I under stand you cannot adjust and the floor
  2. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    shelves are not adjustable.
    dont know the measurements as I am at work :(
    if no-one finds out by tonight - I shall let you know...
  3. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    ok, I has measured for you seeing as no-one else has...
    top shelf : 12cm
    bottom shelf : 17.5cm
    bottom shelf to ground clearance : 5cm
    enjoy.
    mmm
  4. Rookies
    Rookies
    Jan 4, 2003
    4,898
    103
    +344
    Sorry that this is off topic
    But mmm I have PM you.
    Now to topic, this is a very very good tv I have a FQ80 and before this I had the FX66 and the FQ80 beat the FX66 no problem at all the picture quality is much better and more in dept colours etc
