Sony FONTOPIA to Etymotic ER-4P
Discussion in 'Headphones, Earphones & Portable Music' started by Tobez, Sep 9, 2004.
  1. Tobez
    Tobez
    Has anybody done this and gone from the £35 sony fontopias to a pair of 4ps.
    If so did you notice a vast diff or whasnt it worth the upgrade ?
  2. max_keller
    max_keller
    For sound I think everyone would say the Etys sound better. The one thing going for the EX71s in this context is beacause they're inexpensive. I got mine from igearbox.com for £25. The EX71's sound not bad but I have to guess it's not near the Ety level.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Not from that particular model,but I do have a pair of cheap Sennheiser earbuds,and a set of Etymotics...the difference is very noticeable,and to my ears anyway,worth the price differential.
