sony flashing a message at me
Discussion in 'Hi-Fi Stereo Systems & Separates' started by loofer, May 1, 2005.
  1. loofer
    loofer
    Feb 2, 2001
    185
    +4
    Hi, my Sony HT-DDW860 has started flashing the word "protect" every time it is turned on recently, won't put any sound out and then switches itself off, any ideas what the problem might be?
  2. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,261
    Sounds like you have activated the coding protection system (a bit like car radios). Its generally optional, but maybe you ticked the wrong box!
  3. SKA.face
    SKA.face
    Check your cables,your overloading somewhere,so the protection circuit is kicking in,the may be touching each other,or wired wrong,check carefully.UNPLUG FROM MAINS!
  4. loofer
    loofer
    Feb 2, 2001
    185
    +4
    right, cheers i'll have a look.
