Sony FD1 Velocity Modulation
Discussion in 'General TV Discussions Forum' started by Paden, Nov 15, 2001.
  1. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Hello all!
    Has anyone with this set turned off the Velocity Modulation?
    If so where abouts in the service menu did you find the option to do so.
    According to the manual TT54 gives direct control of VM but I don't know how as there is no on screen display.
    (PS Does turning it off make much difference?)
    Cheers, Paul.
