Sony ericssen phone with i mac
Discussion in 'Apple Forum' started by gerbilly, May 4, 2007.
  1. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    the disk with my new K810i is of course pc only. Anyone know how I will get music and photo's on and off??:lease:
  2. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Switch bluetooth on the phone and set to discoverable ... if your mac has blurtooth switch that on ... run through the 'set up bluetooth device' from the mac menu ... you will then be able to mount the phone and drag and drop files to it via bluetooth ...
    You should also be able to use iSync with the phone via bluetooth to keep Address Book and iCal details in check ...
    HTH
    Jon
  3. MacinJosh
    MacinJosh
    What I do with my K800i photos is just plug it in the iMac with the cable provided, select File Transfer on the phone when it prompts it, then iPhoto loads up wanting to import photos. All this without any drivers or software. Bluetooth for everything else like jont said.
  4. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Tried that and you are correct it works thanks.
  5. M.A.S
    M.A.S
    Jan 23, 2005
    49
    +3
  6. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
