Sony DX150 or FQ70
Discussion in 'General TV Discussions Forum' started by Lord Chubb, Nov 7, 2003.
  1. Lord Chubb
    Lord Chubb
    Oct 21, 2003
    20
    Hi all.
    I've ditched my Philips 9308 and am deciding between two sets..
    The Sony FQ70 and the DX150.
    I do like the sound of switching between 50 and 100 when the picture quality is bad, but I haven't read much bad press about the FQ70.
    I use Sky digital, and found the picture bad on the philips.....?
    Which of these television would you guru's recommend?
    Thanks very much
    Alex
  2. Lord Chubb
    Lord Chubb
    Oct 21, 2003
    20
    Can Anybody please confirm that the DX150 will switch between 50 and 100??
    My local sony centre didn't seem to think so..?
  3. bodyfodder
    bodyfodder
    All sony tvs with the DRC feature can do this.
  4. whitcat
    whitcat
    Jul 19, 2003
    36
    SW London
    I agree with boddyfodder that you can choose a non 100Hz mode on the DX150. It's called DRC-50 and still employs some digital wizardry to double both the horizontal and vertical resolution but is 50Hz. The What Video website seemed to prefer that to the 100Hz modes, but as often gets posted on these forums, the reviews should be taken with a pinch of salt. There's no 50Hz option on the FQ70 though.
    Another difference between the two sets is the Scart options. The FQ70 has two RGB scarts but the DX150 only one. This is possibly beacuse Sony thought you would be using the digital tuner instead of an external Sky digibox.
    I personally bought the FQ70 and I am very pleased with it. I haven't bothered to tune in the terrestrial channels yet so I'm mostly enjoying RGB digibox pictures. It does seem to handle terrestrial pictures from the VCR comfortably though. The weaker Five signal gives a touch of flicker although I will notice defects compared to the superb digital picture.
    My FQ70 does suffer with a bit of upward red bleed, which seems to be a characteristic of this set. On most pictures it isn't noticeable but red on white shows it up - e.g. Sky Sports News or the BBC One logo on a white background.
    Thanks to this thread, I might have a tinker, writing everything down before changing anything :cool: :
    http://www.avforums.com/forums/showthread.php?s=&threadid=101549
    The two red settings (cut-off and another) are both set much higher than the blue and green - this could explain the bleed but may mean washed-out reds if reduced.
    Both sets could be bought for about £900 - Currys are even doing the FQ70 for £845 delivered but only until today and online.
    James
