Sony DX 100 problem
Discussion in 'Televisions' started by royalbox, Nov 9, 2004.
  1. royalbox
    royalbox
    Hello all.
    I have a Sony DX100 TV which has recently developed an annoying problem in digital mode.
    The bar that displays briefly at the top of the screen which tells you the station and title of the current program, won't go away. You can sometimes get rid of it by pressing the station button again, or by going to analog and then back again, but not always. Sometimes it doesn't even change when you change channel and you have to switch the set off and on again.
    I was wondering if there was a factory reset I could perform as retuning didn't help.
    Many thanks.
  2. nig28
    nig28
    This appears to be the same fault that occured with some of the earlier sony models. It is a known fault - so you should be able to get some help from the Sony web site. It was a new problem about 2 months ago and they didnt have a solution for it, they might have by now.
    Nigel
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    I have the DX100 with exactly the same problem. As nig28 says, it is a known problem. The latest software r 3.21 [GB] has caused this. I have emailed Sony and am awaiting a reply.
    We would need another over-the-air software upgrade to cure this.
  4. royalbox
    royalbox
    Thanks, it's good to know I'm not alone and that it's a known faullt. After reading several posts on this forum I now know how to find out when updates are due. I'll have a look at the sony website and perhaps if I email them as well about it, it may help a little.
    Thanks again.
  5. royalbox
    royalbox
    Well, I emailed sony a few days ago but they haven't replied.
  6. Phil_S
    Phil_S
    Give them a couple of weeks at least. I have found that I always get a reply eventually.
  7. royalbox
    royalbox
    OK then, will do. Thanks
  8. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    Good News
    Over-air-upgrade available 25th - 28th Nov, Version 3.50
    See here
  9. royalbox
    royalbox
    Thanks simon1. I just got a reply from Sony letting me know about this, let's hope it does the trick.
  10. royalbox
    royalbox
    Out of interest, is there anywhere that tells you what the update includes/fixes?
    Many thanks.
  11. Phil_S
    Phil_S
    Not that I know of, however the current update has greatly improved the performance of the EPG on my DX150 - it is now virtually instantaneous. I have been corresponding with Sony about an aspect ratio switching problem on the ITV channels and Ch4 (where my set often displayed 4:3 programs such as ITV News as a stretched 16:9 picture with the edges disappearing behind the black bars at the side of the screen). Sony emailed me to say that the update should have fixed this as well, and my experience so far is that it seems to have done so.
    The only other thing I have noticed is that the menu option to change wallpaper no longer works - the background option list is empty!
  12. royalbox
    royalbox
    Thanks Phil_S.
    The TV has been updated today and all seems well so far. The EPG is much quicker now as you say (like it used to be in fact). I didn't look at the wallpaper option. I did notice an extra "greyed-out" option; "cam" something or other.
    Anyway, I hope this update sorts out the problem I had and doesn't introduce too many new ones.
    Thanks again.
  13. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    One more new feature:
    See the yellow 'catagory' / blue 'timer' icons, which have an arrow next to them?
    Press the corresponding button on your remote, these icons change '-24hr' & '+24hr'
