Sony DVR-TRV325E,Copy to pc and burn
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jonny.k, May 26, 2005.
  1. jonny.k
    jonny.k
    Hi everyone, :hiya: I am new to this forum but have had my camcorder for 4 years and i would now like to copy my Digital 8 tapes to dvd-r but I don't know what lead or pc interface card I need to do it,so if someone could help me I would be eternaly gratefull,Thanks.. :rolleyes:
  2. Brian110507
    Brian110507
    I would think that if you read through the many many posts in this forum you would find all the information you need to get you started, if you then find you have problems come back and ask again.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    Well as you may have guessed from the previous post we do tend to get asked this question on an almost daily basis. But I'll go through the basics to get you up & running:
    To get video onto a PC from a digital camcorder you need a firewire (aka iLink, ieee1394, DV port) port on the PC. This can be added as a cheap PCI card that plugs into the motherboard for around £10 online. The card should be supplied with a 6 pin to 4 pin firewire cable. If you already have a firewire port (all Macs and many modern PC's do) then you just need a 4 pin to 6 pin firewire cable that should cost you less than £10 online.
    Well that just about covers the connections, but you should do a bit of searching on this forum as there is loads more advise on software and troubleshooting etc. But as Beejaycee said, if you need to ask any more questions then feel free.
    Good luck,
    Mark.
