Quantcast
Sony DVPNS705 Opinions
roofer
have got this player myself, excellent for sacd make sure you amp supports multi channel output as sacd does not work via digital connection/ as for dvd replay great performance great price go for it . hope this helps.
Slime101
it does indeed help :)
It shall be connected to either the Sony Av Reciever 780 or 1080 and a set of missions M's or Kef codas :)
S
SHINODA
Ive also got the same DVD.
I find the picture is excellent also its sounds amazing with 5.1, plays VCD, DVD-R's no problems.
SVCDS dont work with menus, but will play, ive heard this is a firmware block. Im currently looking for a fix on that.
I hope this is of some help.
SHINODA:devil:
