Sony DVPNS305S
Discussion in 'Blu-ray & DVD Players & Recorders' started by sagalout21, Dec 19, 2002.
  1. sagalout21
    sagalout21
    Was thinking of buying this dvd player to replace my old samsung 709 which has stopped playing vcds or cdrs, but I'm a bit confused as it doesnt have RGB output apparently, which is how I currently connect the 709. I was always under them impression that composite was inferior to RGB, which would make it an odd choice for a Sony (all be it budget) system.
    Any advice? Thanks
  2. perrdl
    perrdl
    Jul 29, 2002
    371
    19
    Worcester
    The Sony DVPNS305 does have an RGB output via Scart.
