Sony DVPNS 305 will it play DVD+/-RW?
Discussion in 'Blu-ray & DVD Players & Recorders' started by khalilk, Aug 7, 2003.
  1. khalilk
    khalilk
    Howdy Guys,
    A quick question can my DVD player which is a sony DVPNS305 play DVD+RW and/or DVD-RW?
    your help is greatly appriciated. thanks ... kindest regards
    Have a nice day ...KK
  2. mjn
    mjn
    May 24, 2001
    18,387
    Herts, England
    +5,474
    my 905 does
  3. khalilk
    khalilk
    thanx for the reply .. 905 is a higher spec'd model as compairerd to mine the DVPNS 305 ... but interesting non the less !
    I wonder if it will play DVD rw ? hmmm
    anyways .. MJN can you telll me if your dvd player plays DVD-rw or DVD + Rw?
    thanks ... anyone out there who can give me a definite answer ?
    kindest regards .. KK
  4. pinatubo
    pinatubo
  5. khalilk
    khalilk
    Thanks guys.. i checked out the link above .. and apparently NS305 does play DVD-R's .. but will have to first buy a DVD writer and then burn me a DVD and then check it .. ... okie
    Thanks for all your help ... kindest regards ...KK
  6. mjn
    mjn
    May 24, 2001
    18,387
    Herts, England
    +5,474
    mine will play dvd-rw, haven't got any dvd+rw to try, sorry
  7. Dekim
    Dekim
    Feb 9, 2002
    293
    I have the Sony 305 and confirm it does play both -RW and +RW. I also have Phillips 963sa and it really annoys me that it will only play +rW
    Deks
  8. replica
    replica
    Jun 5, 2002
    5
    I also have a 963sa and it plays -RW without a hitch ! Try Verbatim -RW if you can, it should work !
    Frederic
  9. khalilk
    khalilk
    Thanks for the replies guys...
    I will have to get my hands on a DVD burner .. the one that does both + and - R 's ..if you know wot i mean ... that way i can check both formats ..
    so from the notes / replies above .. it seems that sony DVPNS 305 will play dvd-r for sure as well as DVD+R... kool
    Thanks for the replies again .. regards KK
