Sony DVPCX850 a question?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hammer66, Mar 26, 2001.
  1. hammer66
    hammer66
    What capablities does this player have, I like the multichanger aspect and the superb picture and sound but can it read CD-R?
    Also does anyone have a Daewoo DHC2200 same as Scan 2000 I think, I get a real crappy picture with this player
  2. Ace007
    Ace007
    Hi hammer66,
    Welcome to the Forum! [​IMG]
    I don't know for sure, but if I remember correctly the Sony DVD playeres can't play CDR's
    Manage to find this info on DVP-CX850D:
    200 disc changer forPAL/NTSC playback of DVD video, audio CD, video CD
    -Disc management system, Magic Pad interactive on-screen menu for easy operation
    -Computer keyboard connection capability
    -Sony precision drive base mechanism with Quick Access Drive
    -Dolby Digital MPEG 5.1 channel built in decoder with various Digital Cinema Sound modes, virtual enhanced sound
    -DTS stream-out, 96kHz/24 bit audio DAC, 10 bit video DC, video equaliser
    -Click jog shuttle
    -Advanced Sony smooth scan and smooth slow
    -Disc playback memory, CD Text, DVD Text, screen saver, bookmark memory, strobe memory, video bit rate indicator
    -Control of external CD megachanger
    -BEST BUY: WHAT HIFI AWARDS 2000 - Category: DVD/VCR £450+
    Hope that helps
    Ace
  3. Ace007
    Ace007
    Some more Info:
    TECHNICAL SPECIFICATIONS: Dimensions (WXHXD in mm): 430x198x503
    -Weight: 10kg
    -AC Voltage: 220-240V
    -Frequency: 50Hz
    -Power Consumption: 18W
    -Standby Consumption: 0.5W
    -Precision Drive/DSP Servo/Tilt Servo
    -Dynamic Focus Pickup
    -CD/Video CD/DVD Playback (200 disc)
    -Magic Pad (Graphical User Interface)
    -PAL/NTSC PLayback (Region 2)
    -Video D/A Converter: 10 bit
    -Digital RF Signal Processing
    -Horizontal Resolution: >500 TV Lines
    -Video Equaliser
    -Audio D/A Converter: 96kHz/24 Bit
    -Frequency Response: DVD PCM 96k: 2-44,000Hz (+- 1db)
    -DVD PCM 48k: 2-22,000 Hz (+- 0.5db)
    -CD: 2-20,000 Hz (+- 0.5db)
    -Dynamic Range: 100 dB (DVD), 98 dB (CD)
    -Signal/Noise Ratio: >107 dB
    -Video/Audio Bit Rate Indicator
    -DVD/CD Text
    -Playback memory
    -Disc memo
    -Supplied Remote/Batteries/Instruction Manual/AV (RCA)/S-Video Cable
    Ace
  4. Fartpants
    Fartpants
    This question has come up before, and if you extend the number of days in the search bit up abover you will find it.
    There was a pointer to somewhere that listed what DVD players could play what, apparently there may be some silve cdrw (not cdr) that can be read.
    I haven't tried this on mine yet.
    Dave
  5. Ace007
    Ace007
    Fartpants,
    That's right, while a DVD player may not have CDR capability, most players will happily play a CDRW. I have tested this on a Sony 325!
    Ace
  6. hammer66
    hammer66
    Cheers for the info, I think I'm gonna buy this to replace my current DVD player, if I can find a good price I've seen it going as low as 350 in richer sounds but its gone up again, is there anyone who does a good price on the Sony DVPCX850?
  7. garliadr
    garliadr
    Feb 25, 2001
    817
    28
    +27
    Link Electronics in Peterborough are currently selling it for £389 for a multi-region model.
    web page
