Sony DVP735D
Discussion in 'Blu-ray & DVD Players & Recorders' started by pop, Mar 5, 2002.
  1. pop
    pop
    Apr 23, 2001
    29
    Whitby
    Hi, Does anyone know if there is a "mod" to allow sony dvp735d dvd player to play cd-r disc's
    Thanx
  2. Doubledoom
    Doubledoom
    It's not a software thing. The Sony X25 and x35 models do not have the required laser pickup so it would need a whole load of changing in the hardware and then the software would need to rewritten to take this into account.
    Use Princo brand CDRs and any brand of CDRW as these work fine in the sony models.
  3. pop
    pop
    Apr 23, 2001
    29
    Whitby
    thanx for reply DD
    as you say no prob with cd-rw
    dont s'pose there's anything that can b written to cd-r first to trick player into thinking it's a cd-rw ??
  4. paiger
    paiger
    Most CDR's are simply not reflective enough for the 735. I have heard Princo ones work but have never managed to find any so can't comment.
  5. mjn
    mjn
    May 24, 2001
    18,381
    Herts, England
    +5,464
    the princo CDR's do work as i've used them on my 725
  6. pop
    pop
    Apr 23, 2001
    29
    Whitby
    Thanx for the replys
    I'll try some princo's
