Sony DVP-S735D - Getting It Chipped?!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Saturn82, May 7, 2002.
  1. Saturn82
    Saturn82
    I'm thinking of getting my 735 "chipped." Does anyone know where I can buy the right type of chip for the 735.
    And, where might I find pictures on have to Insatll a chip in the 735?
  2. Guest
  3. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    www.linkonline.co.uk for the paragon uprgrade which is RCE compatible but you need to send your player in.
  4. Craig_Nike
    Craig_Nike
    The chip that needs to be relpaced/modified on the 735 is very small and the soldering is extremely difiicult.
    I have just internet ordered a chip myself but I am paying somebody in my area to install it for me. It is not a job for a home soldering iron.
    Some of the other player have big easy parts to solder, not this one.
  5. Guest
  6. Saturn82
    Saturn82
    btw, Is the Sony 735 a 2001 model?
  7. Guest
    WHAT ? it depends on where you buy the chip ... if the chip is either cheap or easy to fit then NO , if the chip is expensive or difficult to fit then yes
