Sony DVP-S725 v Pioneer DV-626D
Discussion in 'Blu-ray & DVD Players & Recorders' started by MattHughes, Apr 3, 2001.
  1. MattHughes
    MattHughes
    I've been looking at the above players and can't decide between the two. I was wondering if anyone had a suggestion as to which was the one to go for.
    Picture and Sound are my priority.
    Or if these turn out to be a bit shabby, my budgets around £400.00
    Thanks.
  2. Guest
    Go for the sony but get the DVP-S735 instead of the 725 should be able to get it for under £400 by now.
  3. Jenz
    Jenz
    Matt,
    They are both very good machines. You can pick up the 725 at good prices now that the 735 is out.
    If you go the Sony route make sure you get a multimod machine that handles RCE. Some Mods based on Auto switching did not work once RCE appeared.
    Pioneer Mods tend to allow easy Manual setting so its not a problem.
    If I had to choose it would be 725 then 626.
    Regards Neil.
