Sony DVP-S715 Firmware
Discussion in 'Blu-ray & DVD Players & Recorders' started by MartinImber, Jul 12, 2002.
  1. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    What is the latest version of firmware for the Sony DVP-S715.
    Mine is IF Con 2.020 SYSCon 3.2
    And I am having a few problems
    What is the F/W for the CD Enhanced fix?
  2. Tompo
    Tompo
    I'm not saying this is the latest, but my player did have the firmware update.
    Details are:
    IF con Ver.3.010(789A)
    SYScon Ver.2.320(488C)
    Cheers.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    So your player is fine and does not stutter and plays CD enhanced?
    Also is it multi region?
  4. Tompo
    Tompo
    Yes, works fine. No problems playing CD Xtra discs. No stuttering playing DVD's either. It is region 2 only. Had the firmware upgrade since 1999.
    Tompo.
  5. grahamricho
    grahamricho
    Oct 29, 2001
    702
    York
    +13
    just reading a few old posts and saw yours about your sony 715 ,mines been ok untill i bought a dido cd and it wouldn,t play where do you get your upgrade and how and how much does it cost thanks g
  6. PeteM
    PeteM
    Jul 14, 2000
    95
    Maidenhead
    +4
    If you simply want the firmware upgrade and don't care about multiregion and disabling macrovision, then this was available from Sony free of charge, so you might want to talk to them. Don't forget that the 715 went out of production a long time ago!
    I found a mention of corrupt DIDO CDs at the following US website:
    http://fatchucks.com/index.html
    However the UK equivalent makes no mention of problems with DIDO, although this could simply be to noone reporting it yet:
    http://uk.eurorights.org/issues/cd/
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Well I want both but Techronics is based on old firmware!
