Sony DVP-S715 and DVD-R
Discussion in 'Blu-ray & DVD Players & Recorders' started by MartinImber, Sep 14, 2003.
  1. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    I have used a variety of DVD-R and now all my Ritek discs are having problems playing, - OK in my 104 PC drive.
    TDK are similar, however I have had some less purple discs which seem to be better.
    Any make recommended please?
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    If your having problems with a variety of makes of DVD-R then it might be your authoring process that is at fault and not the media. What authoring and burning programmes are you using?
  3. Sheks
    Sheks
    Jul 23, 2000
    523
    England, Surrey
    +24
    I use Panasonic branded DVD-R burnt on my PC. My old S715 seems to play everything I throw at it, far better than my much newer Tosh SD510.
    Regards
    Sheks
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Ulead DVD Movie Factory
    Tried a 9month old Maxell - fine!!!
    They go to menus but tend to stick on playback
    Riteks are very purple!
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    Are you burning with Moviefactory? You might be better outputting as a Title Set onto your HDD and burning using a DVD-Video wizard in a designated burning programme such as Nero (although some people have problems with Nero).
    The DVDR Help site user reports show you machine should play them no problem:
    http://www.dvdrhelp.com/dvdplayers.php?DVDnameid=440&Search=Search&#comments
