Sony DVP S335
Discussion in 'Blu-ray & DVD Players & Recorders' started by sonny, Mar 18, 2001.
  1. sonny
    sonny
    Feb 25, 2001
    423
    Loughborough, Leicestershire.
    +18
    Does anybody have any comments on this entry level Sony player, either good or bad as I intend to buy one from Richer Sounds.
    How reliable is the multi-region mod?
    Any discs it has problems with?
  2. Arthur.S
    Arthur.S
    Well it depends on the mod. I don't know where RS get their players chipped. I can tell you that the player is good. A pal of mine has one. Make sure it has auto & manual region change for RCE compatability.
    www.baldyplex.com
