Sony DVP-S315, 715, 325, 525, 725, CX850D, F11 & DAV-S300
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Justin@UH, Jun 5, 2005.
  1. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Just a quick post to clear the situation on hacks for early Sony models (pre-2000). The following models can ONLY be modified by a direct firmware chip swap, which involves opening your player, and chipping it (major SMT soldering required). There is NO other way to make it multiregion.
    DVP-S315
    DVP-S715
    DVP-S7000
    DVP-S7700
    DVP-CX850
    DVP-F11
    DVP-S325
    DVP-S525
    DVP-S725
    Hope that finally clears this up!
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    Evidently, it didn't :)
    I'm still trying to find the supposed '860 pronto file. IIRC, there was a Norwegian site with some codes on it and they were compiled into a pronto ccf for the DVP-CX860. No idea if it worked but recall reports of sucsess. But let's hope you're right with respect to this vintage of Sony player (I'm sure you are).
    Cheers,
    Mike.
