Sony Dvp-Ns930 Jagged Edge
Discussion in 'Blu-ray & DVD Players & Recorders' started by rmcphail, May 27, 2004.
  1. rmcphail
    rmcphail
    Jan 2, 2003
    35
    HI Guys,
    Have a Sony DVP-NS903 , when i use it with my projector PVL-60 i get a Jagged edge on the right hand side.This is only present when used in progressive mode. i have used the projector with other progressive DVD player and my xbox which runs progressive and it works prefectly.Is it a problem with the Sony or is there something i am doing wrong. :suicide:
    Ray
    Eq: Sony Va555es:Sony DVP-NS930:Sanyo PVL-60 :lease:
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    is the jagged edge actually cutting anything off or is it just as if the image is shifted and this edge is the edge of the picture?
    ad
  3. rmcphail
    rmcphail
    Jan 2, 2003
    35
    It is not cutting off anything ,this seems to be the edge of the picture
    If the above makes any sence ,also svideo seems brighter when used,,
    Ray :hiya:
  4. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    well id hazard to suggest you are simply seeing the edge of the picture and just need to either shift it a bit, overscan it a bit, or a bit of both and you wont see it anymore.
    As for the s-vid, differences are unsurprising since there are very different things happening for each connection
    ad
