Sony DVP-NS900v on Sony KV32FQ75
Discussion in 'Blu-ray & DVD Players & Recorders' started by DavidMalone, May 14, 2002.
  1. DavidMalone
    DavidMalone
    Hi all,
    I was wondering if anyone else had experienced the following problem, and possibly how to fix it?
    When I am watching a DVD, if the screen changes to 4:3 from 16:9 (usually on the extra feature sections of DVD's) my TV changes channel from AV1 to AV2 then back again ???
    I have my sky box connected to my DVD player through RGB, then DVD to TV using RGB (Line1). I have tried removing the sky box from the loop but I have the same problems.
    I found that early French models of this player had the same problem when using the RGB SCART line1, and have learnt that disabling PIN 19 may resolve the issue but I don't know how to do this.
    Obviously I don't want to lose my RGB connection as the picture quality is superb, any ideas greatly anticipated.
    Cheers,
    Dav
