Sony Dvp-ns76h
Discussion in 'Blu-ray & DVD Players & Recorders' started by kevinsmith98, Mar 22, 2006.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    21,616
    2
    5
    163
    +8,168
    Simple answer, yes! I would be very surprised if you don't notice an improvement, in terms of PQ I haven't really seen much better off DVD and I've had some dvd players in my time!
  2. mb2251
    mb2251
    May 5, 2006
    234
    Bristol
    +7
    OK final question, honest!
    What cable have you got hooked up, i was thinking of going down the converter and HDMI->HDMI cable route to ease later av equipment purchases (that may come with hdmi cables..)
    http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/749/vivanco-prowire-hdmi-socket-to-dvi-d-plug/display.html
    and
    http://www.audiovisualonline.co.uk/dynamic/eshop_products.set/ref/816/avo-super-pearl-hdmi-interconnect-2m/display.html
    Would this kind of solution be comparable to a single DVI->HDMI cable set up?
  3. shaolin101
    shaolin101
    Apr 4, 2005
    703
    28
    +41
    Hi, I understand that this accepts divx - does anyone know if it also takes mpeg4/.avi files burned as a data disc?
  4. bazofio
    bazofio
    Apr 21, 2006
    118
    can someone please tell me if the hdmi output gives audio to the tv?
  5. holty2503
    holty2503
    Jul 24, 2005
    117
    Scunthorpe
    zAndy1 have you sorted out the region hack yet, if not i might be able to pop across on saturday as i only live in Brigg.
  6. JAYGAR
    JAYGAR
    Jul 8, 2005
    228
    Wolverhampton
    +15
    Yes it does.
  7. zAndy1
    zAndy1
    Nov 26, 2002
    21,616
    2
    5
    163
    +8,168
    No I haven't sorted out the region hack, would appreciate it if you could pop in sometime, no rush mate, when you're in this neck of the woods will do. Lots going on in Barton this week so you could maybe make a day of it on Saturday, it's the 25th anniversary of the Humber Bridge opening (as I'm sure you know) so there's loads going on here, bearing that in mind it would have to be early on Saturday if that's ok?
    Cheers,
    Andy.
  8. jrecampbell
    jrecampbell
    May 14, 2004
    56
    Some quick questions before I take the plunge!
    1. Does the excellent-sounding player pass blacker-than-black via the HDMI and component connections? My old Panasonic DVD-S75 does via component (which I can tell by using the THX Optimizer at the start of the Star Wars DVDs - the far three left boxes show distinct gradations which are otherwise just black if blacker-than-black isn't being passed from the player).
    2. What are the zoom options. Are they by ratio, e.g. 2.25:1 or by factor 2x, 3x etc. Can you easily zoom out the bars on a cinemascope movie for example?
    Cheers.
  9. Agent Starling
    Agent Starling
    This thread is excellent, and has pretty much persuaded me to swoop on this player now (recently got a new LCD telly, and want to go down the upscaling route).
  10. WGLOVER
    WGLOVER
    Jun 8, 2006
    1,595
    Billinge, Wigan
    +121
    Can you come to Wigan?
    Joking.
    How much is that remote?
  11. lentrix
    lentrix
    Apr 3, 2006
    678
    43
    +109
    Been looking at these HMI dvd players for a while - this has not had 1 bad review so i've just ordered mine.:thumbsup:
  12. Agent Starling
    Agent Starling
    I checked a couple of online places for this yesterday, and they were out of stock. No big deal, and I'm fully prepared to wait a couple of weeks or whatever.
    Can anyone recommend somewhere to buy it? They have it in stock at Play (I think), but I would assume it isn't multi-region from them.
  13. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Will this player upscale to 1080i via component?
    Is there an easy way to region-hack this player - if not where would someone recommend I buy from?
  14. 7up4it
    7up4it
    Oct 29, 2004
    1,633
    Cheshire
    +77
  15. spudgun01
    spudgun01
    May 26, 2005
    114
    19
  16. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    Just got one of these players and hooked it up via HDMI to my Sony 50".
    Picture is great on Revenge of the Sith.
    But having problems with Divx files as they are all being shown as non-anamorphic.
    Can anyone shed some light on this or have I just found a major fault in this player?
  17. steve-p
    steve-p
    Mar 1, 2006
    286
    +7
    I might be wrong but I think it's 576p only from the component output.
  18. gonse
    gonse
    Hello guys. I have a Sony Plasma screen FWD-42v1. I was wondering if I will be able to connect the dvd player in this screen using the HDMI output with a DVI adapter. The problem is that I think that my plasma screen is not compatible with HDCP. Thank you.
  19. husax
    husax
    I have been waiting for two weeks reading the threads and at the end decided to give this player a try, arrived today. For me it's too good and too bad.
    You have probably read this thread so you know what is good.
    The bad is just with divx subtitles (the thing I was afraid of :mad: )
    1- It doesn't support idx/sub subtitles (all current players do), I have a lot of these movies with idx/sub.
    2- Most divx movies that I have, have two subtitles named this way: file.avi, file.eng.srt (Eng subtitles file) and file.de.srt (de subtitle file). Most players that I have tried do support this naming, Sony doesn't. It has to be file.avi and file.srt.
    3- Text subtitles are too small.
    Mediatek based players seem to be the best choice for divx playback / options.
  20. WGLOVER
    WGLOVER
    Jun 8, 2006
    1,595
    Billinge, Wigan
    +121
    I have just found the button on my Panasonic 32LXD60 remote that displays what signal it is receiving.
    With the Sony set to 720p it indicates 720p, with it set to 1080i it indicates 1080i, so good so far.
    However, with the Sony set to auto or 576/480 it indicates 1080i.
    Does anyone else experience this?
    Maybe this is why I could not see any difference between the settings.
  21. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    I am pretty confident in saying that this player cannot display an anamorphic Divx as anamorphic on a widescreen TV.
    I have now connected the player, to my TV, via RGB scart :rolleyes:
    If I play an anamorphic Divx via the scart I can set my TV to "Smart" mode and it will almost make the picture anamorphically correct. It still isn't right though.
    When playing a Divx of Ultraviolet on my Philips DVP5900 the picture is correct and fills the screen in Smart mode (it's 1.85:1), on the Sony, there is still black bars top and bottom of the screen. Plus you have to put up with RGB rather than upscaled. If you go to HDMI the picture is upscaled but is not anamorphic.
    I will also like to point out that the player does not have a memory disc position for Divx.
    So if you have four files on a DVD-R and then stop the playback and turn off. On start up it will take you right back to the beginning of the first data track. :thumbsdow
    I'll be sticking to my Philips 5900 for Divx, Xvid, Mpeg playback as it does it perfectly.:thumbsup:
    If it only had memory resume it would be perfect.:rolleyes:
  22. pzurdo
    pzurdo
    Can anyone comment on whether this Sony player is better than the Samsung HD860? All I want it for is playing dvds to my Samsung LCD via HDMI.
    Many thanks for any direction on this.
  23. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    Follow up to my post.
    I have contacted Sony Technical Department and thay have confirmed that my findings are an issue with this player.
    They are going to look into a possible firmware fix (I'm on version 1.02, with your player off press 1,2,3 power on, using your remote, and the firmware version will come up on your TV).
    They said they will phone me back ASAP.
    I'll keep you all informed.
  24. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Forgive my stupidity here (please don't flame me as in other posts!!!) but what's the great attraction with Divx files?
    Sure, I know that everyone:rolleyes: downloads new movies from the net to watch, but what's wrong with converting the divx file to DVD complient format?
    Then you can have chapters and seeking and memory resume. Oh and the PQ's better too!!!
    Sorry, but I've never watched Divx movies on any DVD player & guess I never will!
  25. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    It takes ages to convert (possibly hours).
    You lose picture quality.
    When I used to convert (using Nero Ultra) I would lose 5.1 sound.
    It takes seconds to drop a Dvix to a DVD-RW and away you go.
    Just tried a MPEG movie file in my player and it doesn't see it at all.
  26. gingerone
    gingerone
    Dec 10, 2002
    2,551
    +376
    I'm seriously tempted by this player, don't use divx so not an issue.
    Anyone using this on a sanyo Z3?
  27. spudgun01
    spudgun01
    May 26, 2005
    114
    19
    Yep, can't argue with the amount of time it takes to convert!
    hmm, losing image quality & using Nero ultra - don't use it !! I use VirtualDubMod, TMEPGExpress3 & AC3machine forthe MPEG/AC3 Encoding & DVDLabPro to convert to DVD complient format.
    But, that's me - maybe I should try viewing Divx files directly :D - do you just burn them to a CD-RW or DVD-RW?
    Sorry getting off topic!!!!
  28. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    Burn the files as a DATA disc, put into machine, press play will take you to root directory (on the Sony this is), enter on root, choose Divx file.
  29. amavadia
    amavadia
    May 8, 2005
    1,263
    38
    +17
    Does this player play .mov files?
    also, if you stuck a HD trailer say onto a dvd, would this thing play it HD? or would it not recognise it because its so high resolution?
  30. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,055
    +609
    It won't play Divx HD I tried so I think any type of HD would not work.
