Sony DVP-NS700H/B and Sony DVP-NS77H/B HELP!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Guinea Pig, May 26, 2008.
  1. Guinea Pig
    Guinea Pig
    What are the diffrences between those two.
    I have bought the Sony DVP-NS77H/B (European Model Sony DVP-NS38 R2)!!!!
    It has the same specs. but the model is different.
    Why does Sony release a new slimmer model and price it cheaper than the older model. (Slimmer design Cheaper Cost maybe) Does this means this is the last dvd player they produce??? Where are the 2008 models!
    I am tired of waiting so I bought the 2007 European model instead and also got the
    Monster-Cable HDMI 750 HD 1mtr :clap:
    I will not use the maximum power but the transfer will be great! Also great if I update to a slimmer Sony blue Ray Disc Player!
    What do you think of this choice!
