Sony DVP-NS355
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by IMAB, Jan 18, 2005.
  1. IMAB
    IMAB
    Nov 21, 2003
    Kent
    Does anyone have a multiregion hack for this please (note it's not the 955 - but if there's a hack for that it's worth a try!).
    It's only a cheapie player used at exhibitions but we may shortly get a region 1 DVD to show and it will save buying a new player!
    Many thanks.
  2. gipo
    gipo
    Dec 22, 2003
    70
    11
    Sligo
    Here is what you need to do to make your player region free.
    1, Get yourself a One For All Signature URC7030 Remote Control. I got my remote from Argos.
    Set Up Device URC7030 Remote
    1, Select DVD device on remote.
    2, Hold Magic button until DVD button flashes twice.
    3, Press 0533
    Set Up Device DVD Player
    1, Put a disc in player and put player onto welcome screen.
    URC7030 Remote
    1, Hold magic button down until DVD button on remote flashes twice.
    2, Press 994.
    3, Press Magic button.
    4, Press 1891.
    5, Repeat steps 1 to 3, then press 2552.
    6, Repeat steps 1 to 3, then press 0953.
    7, Repeat steps 1 to 3, then press 2214.
    8, repeat steps 1 to 3, then press 0795.
    9, Remove disc from the player, then put player on stand by.
    10, Press 12345 (success will be displayed and comes out of stand by.
    11, Press 12345 (player goes into stand by and your player is now region free).
    YOU CAN ONLY NOW CONNECT YOUR PLAYER TO YOUR TELEVISION BY SCART LEAD AND NOT AV CABLE OR IT WILL PLAY IN BLACK AND WHITE.
    GOOD LUCK
  3. IMAB
    IMAB
    Nov 21, 2003
    Kent
    Thanks very much GIPO.
    Do you know if the player will output component correctly or is it just the composite video output that is affected?
