Sony DVP-NS330 remote Control Hack wanted please
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Miyazaki, Dec 27, 2003.
  1. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    Hi, Can anyone tell me how to make this player multi-region please?
    Many thanks
    GG
  2. Family Guy
    Family Guy
    You can't - not using the supplied remote anyhow. Do a search on google. There's a company that will send you the remote to do it with for about £40 I think...if it can be done with a "special" remote - which I'm sure it can...
  3. Pete Delaney
    Pete Delaney
    Read this link, may work for your model also...
    http://www.dvdrhelp.com/dvdhacks.php?select=Sony+DVP-NS300
    Region code hack posted by Ross, November 16 2003:
    You might also like to try this method, which worked for my NS-300, if you have a One4all remote control. This is quoted from http://www.regionfreedvd.net/player/sony.html
    I used oneforall kameleon remote to make my ns705 region free. just follow these steps:
    prepare:
    1. select dvd device on remote
    2. hold magic button until rabbit comes out
    3. enter device code 0533
    program buttons 1..5 with the following codes:
    1 - 189
    2 - 255
    3 - 095
    4 - 221
    5 - 079
    1. hold magic button until rabbit comes out
    2. press 994
    3. press magic
    4. enter 3digit code from above
    5. press button (1..5) where to program it
    6. repeat steps 1 to 5 for all keys.
    have it a go:
    1. remove disk, put player on standby
    2. press 1,2,3,4,5 - success is displayed and plyer starts up
    3. press 1,2,3,4,5 - player shuts down and BINGO!
    should work for most of the dvp-ns### players"
    I used a different One4all and it worked fine on the first attempt. The LED flashes twice on other One4all remotes instead of the rabbt appearing. Hope this helps.
    Ross
    Region code hack posted by ziggy, November 25 2003:
    Just tried this on a new DVP-NS330 using a fairly old URC7541 one for all remote.
    prepare:
    1. select vcr/dvd device on remote
    2. hold magic button until vcr/dvd blinks twice
    3. enter device code 0533, this remote now controls the DVD player
    1 - 189
    2 - 255
    3 - 095
    4 - 221
    5 - 079
    1. hold magic button until vcr/dvd button blinks twice
    2. press 994
    3. press magic
    5. press button (1..5) to program it vcr/dvd button blinks twice
    give it a go:
    obviously most of the above is copied from the above response and all credits go to them.. I just re wrote it as I understood!
    worked 2nd time on my machine.. if it fails first time try putting the machine on, waiting for no disk warning and pressing each numbered button in order.
    enjoy
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
  5. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Yeah this works on the Aiwa AX-10 which is the same player in difference clothes!
    Neil.
