Sony DVP - F11 Multi Region Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Mezz, Jun 4, 2005.
  1. Mezz
    Mezz
    does anyone know a multi region hack for this. Please
  2. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    Press the following buttons on the remote with the player in standby.
    Press Title,Clear and Power On buttons one after another the player should power up into the service menu.
  3. Mezz
    Mezz
    Thanks can't wait to order some R1 DVDs :smashin:
  4. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,173
    63
    Location location location
    +93
    ? Sorry but this won`t help MEZZ!! All the above does is allow access to the players service mode to show its current settings, and to re-calibrate the drive alignment! You CANNOT change its regional code setting this way!!!
    The only way to change this players region is by physically opening the unit, removing its 44pin SMT firmware, and replace it with a new one that has been modified. Sorry, no handset hacks or other secret codes.... NO other way of modding this, or other players from Sony of this age (its over 5 years old!) other then "chipping" it...
  5. Mezz
    Mezz
    Oh big hairy balls that sucks :mad: oh well guess i will need to get a new player then any ideas on a decent multi region sony or other branded ones.
  6. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,173
    63
    +93
    If you like the style of your existing DVP-F11, sony still make similar models to this, which can be bought either pre-modded, or as R2 and then modded easily yourself, such as a DIY mod.
    Current version of the F11 is the DVP-F35, which you can buy online pre-modded from many dealers.
